2000 Bourget Fat Daddy 240mm
  • Thread starter LukeLewis
LukeLewis
LukeLewis
Pro Member
This gorgeous Bourget originally cost over $60,000 which included over $10,000 worth of custom work done to it. It was a beast to start with its S&S performance built 113” engine fed by an S&S shorty carb that sounds just plain nasty ripping through its custom built exhaust. As if that wasn’t enough the original owner had a custom nitrous system installed which not only looks wicked with its two 1 pound cylinders custom mounted inside the 6 gallon gas tank but it gives this bike the potential to scare the daylights out of you. It was also upgraded with progressive heavy duty softail shocks and it looks wicked with its 240mm rear tire and 21” front rim. It has an inverted front end with a 40 degree rake which perfectly complements the 2 inch stretch in the neck and the extra 6 inches in the backbone. Everything on this bike is chrome, polished or painted and the bike shows like it has 500 miles on it. It currently has 6,288 miles and was just completely serviced at which time it received new tires, new brakes, a new battery, new fluids and filters. She is in perfect working order and is need of nothing but someone to enjoy her. With over $60,000 invested in the build of this bike it is destined to sell as quickly as it moves so if you like what you see you better pick up the phone before someone else does!
John D. Moore
STERLING MOTORS INC
www.hotrodschoppers.com
00 Bourget Fat Daddy 001.JPG 00 Bourget Fat Daddy 014.JPG 00 Bourget Fat Daddy 015.JPG 00 Bourget Fat Daddy 016.JPG
Bourget
Fat Daddy 240mm Custom
$9,900
Sterling
Illinois - IL
