2022 BETA XTRAINER 300 2 STROKE
  • Thread starter Ruhnke's
377 Total Thread Views
Ruhnke's
Beta-Built single cylinder, 2-stroke, liquid-cooled, with BPV power valve system and counterbalancer, electric start with a backup kick starter sold as an option Bore: 73mm Stroke: 69.9mm Displacement: 292.3cc Compression Ratio: 11.55:1 Exhaust Valve: Beta Progressive Valve (BPV) Ignition: AC-CDI Kokusan Spark Plug: NGK GR7CI8 Lubrication: Electronic Oil Injection Oil Tank Capacity: 650cc Carburetor: Keihin PWK 36mm Clutch: Wet Diaphragm-Style Transmission: 6-speed Final Drive: O-ring chain CHASSIS SPECS Frame: Molybdenum steel/Parameter-Style w/quick air filter access Wheelbase: 57.8 Seat Height: 35.8” Ground Clearance: 12.6” Footrest Height: 15.4 Dry Weight: 216 lbs. (wet weight, no fuel) Fuel Tank Capacity: 2.25 US gallons Front Suspension: 43 mm inverted front fork with adjustable dampening Rear Suspension: Steel body shock with adjustable rebound and compression Front Wheel Travel: 10.6” Rear Wheel Travel: 10.6” Front Brake: 260mm floating rotor
Pricing displayed may not include Government fees, Taxes, Titles, Tags, and Dealer processing fees. Contact Ruhnke's Xtreme Cycles for complete pricing info. 432-563-0000
New
Other
$8848
Odessa
Texas - TX
